Bike lane around the hospital (again sorry!)
@NathanK one for you and your Hospital Project contact?
Sometime in the past week or two it looks like a vehicle has run over / pushed one of the concrete timtams at the start of the bike lane cnr of St Andrew and Castle. Either that, or it was moved to give drivers turning right from St Andrew Street a lot more room. It means the entrance is now about half the width of the original cycle lane. Not too much of a problem when riding straight down the One Way, but makes for a precarious turn when coming from St Andrew St, heading westward, and turning left into the lane, especially with the closeness of the handlebar to the Blue Arrow sign.
Thanks Gerard for the report!
I’ve sent a link to your excellent description to Jason, and asked him to take a look.
Thanks Nathan, much appreciated!
Pure speculation, but I suspect it’s not being returned to it’s previous position after they closed off the cycle lane recently overnightto do some underground work.
If so it could be worth them looking at systemic fixes so workers don’t make similar errors in future
I spoke with Jason last evening - he took a look but couldn’t see the problem. Unfortunately I wasn’t able to swing past to take a look myself.
If anyone can get eyes and a few more photos on this, that would be very helpful.
Traffic cone for scale. It’s not as bad as the other pinch point was, especially as the corner is very gentle. (Edit the corner in the cycle lane, not the entry to it) But definitely narrower than the lane for the rest of the block
Another frustrating feature there currently is that the cycle light does not go green, so the only ways to legally cross are to shift over to the regular straight through traffic lane or dismount and push the pedestrian button, (cycle light stays red, even though the traffic turning across it has a red filter. Only the pedestrian light went green.
Thanks for those photos Robyn. I just realised why turning into that lane feels so difficult - the angle is even tighter than the original 90º now when turning left into it.
For the cycle light, it’s worth logging a separate signal fault with the council and noting the direction and time; if it’s a detector loop, the green may only trigger when a bike is positioned over the marked spot. The narrowed entry and the red bike light are distinct fixes — the concrete block needs a site visit, while the signal may be a detection or configuration issue.
